Hose Diagrams
tony barnhill
Great Pumpkin - R.I.P
Get a Moss catalog - there are diagrams in it...might want to even check the moss site to see if the diagrams are on there
I have the Moss and Victoria Catalogs both showing the hose, but not where it leads.
I aquired a 79 MGB this weekend. It needs work, but I'm looking forward to it.
I was hoping someone has a hose diagram. Most of the hoses need replacing. There is a coolant hose coming from heater box to the automatic choke, then to a tee that loops back to the choke, and finally to the bottom of radiator. It seems the tee shouldn't be there, i.e. it should go heater box, choke, and then radiator. A side note about the tee; it’s galvanized house plumping pipe
I did a search, but didn't see any posts.
Several of the links mentioned and books are used often... Moss, Haynes manual, Bentley manual, and others. But I have actually used this site in the pictures section for reference also. Go to "links" above and pull up "members rides" and look at the pics... many show engine compartment and detail. A bunch of us are as proud of the under side as the top side since we see that view so often.
