[ QUOTE ]
Steve S is right about the block, but the '72-'74 cylinder head is know for the best factory flow rates and compression, with larger valves. Its the performance head of choice!
[/ QUOTE ]
Ok, what would be the advantage of putting a 72 head on a 67 block. What about compression ratio? Was the 67 with the stock head 9/1 verses 8/1? Does the port holes, even though plugged, in the 72 head drop the compression ratio? PJ
