Nelson
"High" temperature adhesive
Last summer I had some problems with vapor lock and I'd like to avoid that problem this year. I have some insulation material that I would like to install on the back side of the carb heat shield. It is a foil type material. I'm wondering if I could glue it to the heat shield with some sort of adhesive but I'm concerned that the temperature might make the adhesive not hold. I have some spray adhesive that I used to fasten the inside panel coverings but I'd be willing to buy whatever will do the job. If it will be too hot for any adhesive I would have to just use some small machine screws as fasteners.
Hi Guest!
