jmayled
I have just replaced the points on my '75 TR6 with a pertronix electronic ignition (The ignitor model) & while it cured my rough idling issues, it rasied the idle from around 1000 rpm to 1800 rpm.
This issue is constant and remains at 1800rpm whether the car is cold or warm.
I have checked the choke conenctions to make sure they are not sticking, checked for Vaccuum leaks, tried the carb cleaner trick although I'm still at a loss why this car is idling at such high rpm's.
At this poin I'm not sure what my next step would be to reduce the idle. Can I adjust the idle by rotating the distributor until the lower rpm is reached? Can this be done while the car is running?
Any help would be greatly appreciated! (Thanks again Guys!)
