Hi Guest!
Usually, they can tolerate a bit more timing at higher altitudes as well. But not much, and it doesn't seem to make all that much difference. ISTR I added about 4 degrees at about 10000 ft (VTR at Breckenridge, CO) and one or two flats leaner on the carbs. But it will still never make as much power as it did at sea level.
Rad cap is straight 15# Will go to the 18-21.
Harry
