Did a carb change from a single Strom on my 77. Rebuilt HIF’s and changed all the stuff needed but when I turned pump on rear carb leaking gas. Front seemed ok.....float problem? I did check for crackers before installing and seemed fine. Put in new needles with rubber tip. Might be stuck? Also do carbs have to come off ?
Bob
Bob
