Just when I thought I had seen it all (silly me!!)I had a problem that when I started my car (after putting it back together - see earlier post re winter project)the starter kept running after the engine started. There were a couple of other strange happenings of a similar sort going on as well.
After quite a bit of time going over the wiring diagram I recalled an offhand comment that the owner of the service shop that I use had made that in the 76 MGB the car was known to occasionally start by using the handbrake!!! Sure thing!!!
Well, it turned out this is what was going on in my car. With the handbrake on the starter kept going, when it was released the starter stopped!
If you take a close look at the wiring diagram, and don't get dizzy following the wires you will find that the green wire from the handbrake light switch and the red and white wire from starter solenoid end up at the same place. If the green wire is not totally above ground (no resistance) it will keep the solenoid relay coil from releasing. At least that's how it looks to me at this point.
This has got to take the record for the strangest cause of an electrical fault in my limited car experience.
Isn't it FUN working on these wonderful cars???
Al
/ubbthreads/images/graemlins/canpatriot.GIF
Al
