OK, now that I've got your attention... /ubbthreads/images/graemlins/grin.gif
I bought some very nice rims for the B, but am in a bit of a bind. They're 3/4" more positive offset than the Rostyles, and 5.5" wide. This means when I get them fitted even with conservative tires (185/70's), they're probably going to rub the inner wells. I can solve part of the problem with spacers (no more than 1/2" will do, I think), but I need longer wheel studs. I've searched all over Clarksville, and can't seem to find a match. The problem is the shoulder of the studs on the only ones I can find are thicker than the stock ones. I can make these work if I have all the holes drilled out, but would rather not do that.
Anyone have a source you can point me to?
Or has anyone else had this problem and solved it otherwise?
Finally, can someone measure the width of their 185/70's mounted on 5.5" rims so I can double check my clearances?
Thanks,
Mickey
Thanks,
Mickey
