Got_All_4
THIS IS MY FIRST POSTING! IN A COUPLE OF DAYS I WILL BE MOUNTING MY GOOD PARTS TIPPLE STROMBERG SET UP ON MY TR250. WOULD LIKE SOME IN SITE. I PURCHASED 3 CARBS FROM TEAM TRIUMPH OFF A 1971 TR6. OF COURSE THEY NEED REBUILT AND I HAVE THE KITS. I PLAN TO GET A SET OF NEW NEEDLES SO I KNOW THEY ARE ALL THE SAME. I PLAN ON FOLLOWING RICHARDS INSTRUCTIONS BUT WE ALL KNOW HOW THAT ALL GOES. I PLAN ON RUNNING A HOSE OFF THE VALVE COVER INTO A OIL SEPARATOR AND THEN INTO THE CARB VACUUM PORTS. MODIFICATIONS TO THE MOTOR ARE 10:1 COMPRESSION, ROLLER ROCKERS, VALVE GRIND, PORTING, TOTAL SEAL PISTON RINGS, 6 INTO 1 HEADERS AND A REGROUND STREET CAM. SPECKS ON CAM ARE; DUR INT 250, EX 254, INT OPENS 17 CLOSES 53, EXH OPENS 60, CLOSES 14. RISE IS 255 AND L/C IS 108. LASH IS .014. ANY HELP IS APPRECIATED. LOOKING FORWARD TO A GOOD RELATIONSHIP HERE. THANKS IN ADVANCE.
