Stirkle said:
Up until a few days ago it would start and run fine but now it starts sporadically and when it does it will run for about 10 seconds and die. When this happens, no spark at any plug or distributor cap. I bought and replaced the Lucas coil today and still does the same thing. Everything is original that I have seen so far. The car still had the 3 original Lucas fuses. I have replaced them also. Is there a way to test the electronic ignition module?
I don't know how you might test the electronic ignition module itself, but if you are not getting any spark at all, then you might try to eliminate other causes and maybe get down to the module that way.
You have already replaced the coil, so rule that out for the moment. What about the cap? Does it have a good graphite centre electrode? Is the cap cracked at all? Does the rotor look ok, not split? You can test the high-voltage wires with an ohmeter to make sure they're not shot. If you're not getting any spark at all I would only worry about the wire from the coil to the cap at that point.
Did you try checking to see if you have power to the distributor? Look for where the distributor plugs into the wiring harness (a 2-piece, lock-sided connector at the dizzy). If you unplug that, you can test to see if you have wiring-harness voltage at the center terminal (white wire), using a test light or voltmeter. If no power, then you have got a problem in the harness or at the fuse. You can also check for voltage at the white-wire side of the drive resister (square aluminum block should be mounted close to the dizzy with a white wire and white/blue wire connection).
If you have power going to the distributor, but no spark, then test the harness connections at the coil and the wire from the dizzy to the coil. Reconnect the dizzy to the wiring harness, and disconnect the ignition wire between the coil and the cap. Unplug the + terminal at the coil (white/yellow probably) and check for continuity to ground. If not, you have a problem in the wire harness between the coil and ground. (If you have a little blue capacitor connected at the + terminal, just unplug it also and leave it unplugged while you test.)
If the + side of the coil is ok, unplug the terminal connection at the negative side of the coil (white/slate wires) and connect a voltmeter or light between the white/slate terminal and a good engine ground. Crank the engine a few revs to see if you're getting any voltage registering at the coil connection as the distributor makes/breaks. Its a pretty short pulse, but you may be able to see it with a light. If so, your dizzy is probably ok and I would be back to looking at either the coil or the high-voltage circuit (wires, cap, rotor).
I would be careful not to leave the ignition switched on too long with a circuit through the distributor to ground. You can easily burn out the module just by leaving the low-voltage ignition circuit on without running the car. You may have already done that inadvertantly while trying to get your wiring right, but hopefully not.
If you find you have no power on the white-wire circuit, go back and look at the top fuse one more time. Both sides of that fuse support different circuits, and I have had problems myself where one side of a fuse (e.g. green circuit) is fine, and the other side is not, but the fuse is ok. Check the connectors carefully.
