Will I found out that I had a tooth come off a gear. It appears that it is on the counter shaft that I cannot see. I am trying to get the input shaft out but it will only move about a 1/4 inch and it seems to be hitting someing. I have a tube that is shorter that the counter shaft and the counter shaft gear set drops about 1/8 inch down at the input shaft gears. All the manuals I have say just pull the input shaft out. One manual shows a special puller the other does not say anything special. I have been heating the case which help some to where I can slide the shaft and bearing assy the 1/4 inch easily but is stops on something. I think the counter shaft gear set needs to drop more. Am I missing something the manuals are not saying.
