chicken
Hi guys i need some help with starting my BJ7. So far i have:
1) fuel up to the carbs
2) a spark on at least 1 plug (must confess i havn't checked all of them, is this necessary ?)
However after opening the throttle slightly on the screws and with the choke out all i get is an occasional fire here and there, it's as if it's backfiring (popping)as sometimes it blows back through the carbs.
What ever am i doing wrong, i can only presume that it is not firing in the right order or perhaps a fuel problem, i know the firing order is 1,5,3,6,2,4 and take it this is the order the HT leads should be in coming from the distributer (anticlockwise) but do the cylinder numbers start from the front of the engine (rad end)?
I have also turned the distributer but this doesn't help alot.
I feel i'm nearly there !!!!!!! Help
