Hello everyone,
I have rebuilt my TR3a engine and I haven't managed to get very far with tuning it. The engine uses 5 litres of fuel in around 10 minutes. I know this sounds impossible but its happened each time between 5 - 10 runs in the garage just trying to get everything warmed up and good to go so I can begin tuning. The engine is timed statically and the carbs jet screws turned down a few flats as per the book initially but its possible I have abandoned that and adjusted them up as much as possible to try and shut the fuel off. I have made a 5 minute film on youtube where you can listen and view the engine. Maybe you can spot something. I'm just about out of every single idea. You'll hear that it sounds like its missing and just running on two cylinders. I've done the whole pulling off leads from plugs thing to no positive result. The oil level is normal ( not increasing with petrol in the sump). The garage stinks like **** after the fuel runs out even with the doors wide open. It is as though the unburnt fuel is being pushed right out the exhaust. The carbs are as good as new. I had Burlen fuel refurb the throttle bodies and ream for new throttles. All stops and wear parts replaced. No air or fuel leaks. Compression check is constant on all cylinders. Float assemblies doing their job. No fuel escaping down the overflow pipes. Block has new pistons, rings, crank and bearings. Head gasket new. Tappet clearances all ok. Valves respond well with a light hammer tap and spring as they should. All new ignition parts.....
here is the link to youtube: https://youtu.be/EHQ-MRKqM9g
Would really welcome feedback! Don't worry about hurting my feelings. If I've done something stupid and screamingly obvious I'll be the first to laugh ( well after you've pointed it out, which makes me second..
Many thanks.
Many thanks.
