There are a bunch of expert engine builders here so let me know what to do.
I got my engine head back and taking a look at it I noticed that several of the springs / valves (all the exhaust) appeared higher than the others. pushing down on the valve (with my calibrated thumb), it is clear that the spring is not generating enough pressure.
According to Bentley, the fitted length should be either (a Herald 1200)1.36" w/27 to 30lbs load or 1.07" with 117lbs load (spitfire) Presumably the difference is a more aggressive cam on the spit??
In any case, the exhaust spring installed length is closer to 1.5" and way below 30lbs of force. squeezing the springs against the bathroom scale showed that if they are compressed to the correct length (whatever that is), the load generated will be correct. (springs are new)
Now as I understand it, I need to add shims. Where exactly do they go? under the bottom spring collar ? between the collar and the spring?
Clearly if they go under the lower collar they need to hardened. Can I just use "standard" washers and put them between the spring and bottom collar?
Thx Yisrael
Thx Yisrael
