simpzimmer
I tried to crank up the Spitfire this morning. I had let it sit for a few months. Bad Idea. I replaced the diaphram in the carb. It had a hole in it. When I cranked the car, it idled, but wouldn't do much else. I tried the adjusting screw, but nothing really changed. The car will idle, roughly, but won't respond to anything else. I try to give it gas, and nothing happens. I replaced the diaphram again to see if I had a bad one, but nothing changed. Any ideas?
Hi Guest!
