I hope someone can offer some sugestions as to whats causing the engine on my 67 BJ8 to just randomly conk out while driving. The last few times while driving the car, it would just stop running for no apparant reason. When stopped it sometimes takes a few minutes then starts back up and drives fine for a few miles and conks out again and some times it starts right back up and does it again. My first thoughts were electrical because it didn't sputter to a stop and I could hear the fuel pump working. My car has the Crane Cams electronic ignition with the XR3000 ignition module with the LX91 electronic coil. I thought it could be the coil over heating and replaced the coil that didn't resolve the problem. The LED indicator on the ignition module is lit when I try to restart so that seems to be working OK. Maybe its not electrical. Possibly something else. OUT OF IDEAS
I would really appreciate anyones suggestions as to what might be the problem, what to test and how, and what I can do to fix it. thanking you in advance for your help. puzzled in Alexandria
Hi Guest!
