Johnny
Anybody have any good ideas on how to install a transmission back in the car, with the motor still in the car?
I didn't have much trouble removing the transmission, but now after the rebuild I've got to wrestle the "green dragon" back into the car.
Things I've tried; Used all-thread to line up the transmission (didn't work), Use every large-round screwdriver to align, that didn't work either due to the sides won't go in.
Raise the transmission from underneath with a floor hoist and slowly push into engine.
Things I've learned; If you first twist the front of the transmission you can clear the sides. Once clear it'll slide up to about 1 1/2" then stop.
If you put the transmission in gear you can turn the third member (where the driveshaft mounts) to try and align the mainshaft with the pressure plate. Please HELP.
Thanks to all who responded. Bob, I have the correct alignment tool but I now realize if there's any resistance at all removing the alignment tool you'll never get the transmission to go in. So, now I'm waiting to build up some reserve energy for another attempt at the "gold medal". I'll let all know how it went, or didn't.
Yes, I got it in!!!
