mechwanabe
Member
Hi: I was cleaning around the engine of my 66 AH and now the coolant sensor just below the thermostat is leaking. Was able to remove to inspect and looks OK! but, how is it supposed to seal?. There was no o-ring or gasket between the nut and the sensor tip. If you have seen one you will know what I am talking about (its a bit difficult to explain).
Thank you for any advise on this..
