Nunyas
Hey folks,
I did some work on my car this past weekend, and took her out for a spin (15 - 20 miles). Everything seemed to be running ok some minor adjustments (to get rid of a stumble under acceleration from a stop) would help, but ok overall I thought. When I finished the drive, I let the car idle and popped the hood checked the fuel filter; it appeared over half full initially which is better than normal after a drive that distance. Then as I was looking at the filter I noticed the fuel level in it started dropping very rapidly it emptied in under a minute with the engine idling after the drive. When the fuel level in the filter started dropping rapidly there was a notable change in the engine idle... it behaved really lean: unsteady idle speed, random sounding misfire, and "splashy" exhaust note. The only thing I can think of to cause this is maybe a lack of air flow evacuating the exhaust heat from the engine compartment, and the fact that I have only half the original heat shield pieces in place (I got the car with NO heatshields). I'm considering getting some aftermarket moldable heatshield material to attempt to block off the remaining exposed areas of the exhaust manifold from the carburetor area.
I had a question to ask at the beginning of all this, but I seemed to have strayed a bit. More to the point I want to know about is no matter how fuel rich I make the mixture in my carb I can't seem to be able to get rid of a stumble from idle. Lately, it seems to be getting worse, and it definitely seems to be worse when the engine is fully warmed (e.g. driving in city traffic is becoming less and less "enjoyable" due to the stumble from a dead stop) than when just started. If I rev the engine before attempting to move the car I can usually get a smooth start from a stop light, but the longer I drive the car the higher I have to rev the engine to keep it from stumbling. So, by the time I get to the last stop light from my house I have to rev the engine to 2000 - 2500 RPMS (and sometimes even higher) to keep from stumbling on take-off. Steady state driving with the engine RPMs over 2K seems to be ok with little to no hesitation. I'm beginning to suspect that I may have a partially clogged catalytic converter, but I'm uncertian on how to check without cutting up my exhaust. When the engine was fully cooled I tapped on the cat (after market non-stock cat) and it sounded "solid" (as in not hollow), and I tapped on the muffler it sounded hollowish but without any reverberation (like a metal container with heavy sound deadening). I don't think this is anyway to determine if a cat is bad, but short of removing it I'm not sure how else to tell. Any of you know? Also, can a partially/mostly clogged exhaust cause all of the behaviors I'm getting (e.g. heat build up in the engine compartment, heavy stumbling at low RPMs, etc.)??
Thanks for any information you guys can shed on this topic. /ubbthreads/images/graemlins/smile.gif
