I am having some problems with my horn and heater switch. The horn problem seems to be in the contact plate below the steering wheel. When I got it back from the body shop, the horn would sound when the sterring wheel was pushed or pulled. I removed the horn button and contact spring, and it still does it. The contact ring is shorting out some how. Anyone had this problem?
The second electrical problem is in the heater switch. I have power at the switch, but the blower will not work.
If I attach a ground to one of the blower motor terminals the fan will blow on high in the off position, low in the second position and blow a fuse when in the high position. if I take the ground off the blower terminal, the motor will not work at all. I have tried reversing the two wires feeding the switch, but no results. The wiring diagram in the work book is less than clear, and it gives no close pictures of the switch, or even a schematic of it. Any body have any sugestions?
Three hours and five fuses and no further ahead.
