I'm wondering which hose on the firewall is the inlet hose. I believe it to be the top hose since it goes to the top of the engine to the control valve. Is this assumption correct? Thanks
Whichever one seems to fit best, it doesn't really matter.
Did you consider changing that little two-pipe firewall thigamajig? These things are famous for corroding out. TRF usually has them in stock.
