Heater Hoses...
asoupley
I am finally getting my cooling system finished! When installing the heater, I know that the hose from the left of the heater goes to the garden hose lookin' valve, but where does the hose on the right go?
Thanks!
-Tony
Up front to join up with the lower rad hose and water pump, IIRC.
Good to see ya back, BTW!
Yes, goes over the left side of the cyl head behind the carbs, then bends down and attaches to a rubber hose at a right angle, the same hose that goes from the bottom of the rad to the water pump.
Is a special radiator hose with a teat for the heater hook up.
Ok, I was wondering where that small hose on the lower rad hose went. I'm getting so close I can taste it!!
Thanks!
Hehe, just close off the valve and to heck with the heater till you get the right hose.
