heater blower wiring
jvandyke
Still tinkering with new harness.
I have a GY with a bullet end right by the fuse box, which I believe should go to the blower for the heat. Can't quite figure out what would be the comparable end on the dash side though, to connect to the switch, anyone have a clue? I can start testing all the mystery wires but there was no GY there that I saw.
Should be a green with a brown strip under the hood from the switch. Other side of the switch should be a solid green from switched fuse. Thats whats on my BE.
MK2 sprite mk1 midget Green Yellow strip is from the heater motor to the switch. Other side of the switch should be a Solid Green from switched fuse.I think most later were this arrangment.
yep, can't find the GY behind the dash though, just in the engine bay....
Later that day (early the next day)
found it....looked like all the other solid green ones until closer inspection....
