healey bt7 fluid change questions
tri_carb_healey
hello yet again. with the car starting it's time to replace all the fluids. before do so i need to know how many quarts my healey takes and also what are the steps to flush the radiator?
tri_carb_healey said:
hello yet again. with the car starting it's time to replace all the fluids. before do so i need to know how many quarts my healey takes: SEVEN AND 1/2 QTS.
DRAIN THE RADIATOR AND THE MOTOR. THE DRAIN FOR THE MOTOR IS ON THE DRIVERS SIDE OF THE BLOCK. REMOVE THE THERMOSTAT HOUSING ON THE TOP OF THE BLOCK AND REMOVE THE THERMOSTAT. REASSEMBLE THE HOUSING TO THE BLOCK W/O THE THERMOSTAT. FLUSH THE RADIATOR PER INSTRUCTIONS AND MAKE SURE YOU FLUSH THE BLOCK WITH CLEAN WATER AND DRAIN. REPLACE THE THERMOSTAT AND GASKET AND FILL THE BLOCK FIRST WITH 50/50 WATER AND ANTIFREEZE SOLUTION UP TO THE TOP OF THE MOTOR (WITH THERMOSTAT AND HOUSING REMOVED) INSTALL THE THERMOSTAT HOUSING WITH A NEW GASKET AND THERMOSTAT AND FILL THE RADIATOR WITH 50/50 MIX.
A mixture of white vinegar and water will loosen calcium & oxide deposits.
If it's an old system, drain the coolant from the block and radiator, refill with the vinegar and water solution (I use 50/50 here too, and the vinegar is cheap enough). Drive it around the block a few times, and then let it cool down enough to drain it again. If it looks particulary bad, you can do it a second time.
If you can still see stopped up tubes through the radiator filler neck, the radiator should be pulled for a professional "rodding out" procedure.
Backflush with water by undoing the hoses and introducing the water in the reverse direction of normal flow.
Take note of the condition of radiator and heater hoses, replace any that are suspect.
Close everything back up, and refill with 50/50 antifreeze and distilled water. Barring any leaks, you should be good for at least three (3) years.
Considering where you live, a thorough job of checking out the cooling system can avoid a lot of trouble later on.
I am somewhat embarrassed to admit how long I go between antifreeze changes on all my vehicles, including the Healey. Probably closer to 5-6 years. My 1981 GMC truck, maybe, has only been changed a couple of times. Only issue I ever had was the Dex (orange color) antifeeze that some manufacturers used around 2000 that turned to mush after a couple of years. Anyway, my opinion is that sometimes we change fluids more often than necessary. Probably just opened a can of worms here.
