Healey 100
Healey friends:
I am sure none of you are shocked to hear that Healey's leak from the rear main. My 100 has leaked for 35 years, I have grown accustomed to it, though I hate the mess it leaves when I park it.
What's new is that I have just rebuilt the engine with new bearings, pistons, rings, etc. She runs great, but her rear main oil leak seems even worse now. If I drive her hard for a while, the oil seems to collect somewhere in the bell housing, and when I slow down or stop, a ton of oil comes out quickly, making a thick slippery spot about a foot in diameter!
I know the 100 has no seal per se, but it does have a drain to catch overflow and direct it back into the oil pan -- through a little tube attached to the bearing housing. I was wondering if this tube was necessary. Won't oil flow out the drain much faster without the tube? The tube is about 7/16 OD, 3/8 ID by 6 inches long. I would think gravity flow through a short 7/16 hole would be a lot greater than through this tube. But I am sure it was put there for a reason.
It would be relatively easy to remove this tube. Does anyone have any other suggestions? I need to fix it quick or bring lots of oil and the hazmat team with me to San Diego....
Bill S
Albuquerque, NM
Bill S
Albuquerque, NM
