Bob_Bobrowski
My headlights work only on ther high beams, not the low. I don't believe both bulbs are burned out. Could the problem be with the switch, or should I look else where? Thanks.
Bret said:The odds are slim that both headlights would fail at the same time aren't that great.
Why do you think I suggested checking the voltage at the headlights? /bcforum/images/%%GRAEMLIN_URL%%/smirk.gifTullamore said:Bret said:The odds are slim that both headlights would fail at the same time aren't that great.
Making basic assumptions like that usually makes me spend a lot of time trying to solve a problem that never existed. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
aerog said:Have you check your headlight fluid lately? Could need to be changed, and try synthetic it lasts longer.
(sorry, couldn't resist - do what Bret said and check the voltage)
tony barnhill said:But brake light fluid is the same as what you put in your master cylinder...you just have to use a syringe to get it in the end of the little bulb.
