A previous owner fitted halogen headlights, spot lights and a flick switch to flash the headlights operated through relays. I'm no electrician but the wiring needed tidying up so I've been tinkering! I don't have a circuit diagram but I discovered that there are 3 15 amp fuses which come off the 87 relay terminals feeding the hi, dipped and spot lights. There are also two 35amp fuses which I think are the power sources to the relays. I'm not sure what size these fuses should be, 35amp seems a bit high to me and I'm a bit concerned that they seem to be wired in with 15amp connectors, perhaps I should uprate these to 30 amp. Any suggestions on fuse sizes would be greatly appreciated.
Thanks
AJ
Thanks
AJ
Hi Guest!
![Headlight Relays[1].jpg Headlight Relays[1].jpg](https://www.britishcarforum.com/community/data/attachments/35/35126-d1930e021be1f8ae19ee9bf256123939.jpg)
