duplaga1952
Member
i've heard about headlight and horn relays . where else would a relay help the electical system ? do the brake lights need any assistance ?
tweety said:Instead of rewiring the tail lights (all of the them) with relays, I replace the bulbs with LED's. Much brighter and far lower current draw..... So far so good..
Pythias said:The only reason to use relays for the headlights is IF you are using NON-STOCK lighting, like H4 or H6 bulbs. The stock headlight switch was designed to carry the current of standard sealed beams. Same with the horn. the stock ring will carry all the current needed for even dual horns, as it was DESIGNED to do. ..
tosoutherncars said:Your understanding was right, JP.
These switches were NOT designed to carry full current for fifty or sixty years. And, these are cars that were built as cheaply as humanly possible. (No trunk or door handles, anyone?) Priced out a NOS switch lately? Ouch.
Pythias said:If it makes one feel better to use relays and complicate the wiring of one's car, go right ahead. One more point to trouble shoot never really hurt anything. IF one want to run larger wires to lessen resistance, do it. But do them for the right reason, one WANTS to.
