I'm about to start uprating my headlamps on the BJ8 with quartz Halogen lamps fed via relays. I want to check the front fender alignment before I start. Can anyone tell me, with the headlamps removed and just the steel bowls and their rubber gaskets installed and with the car standing on level ground, should the bowls be vertical as measured with a spirit level across top and bottom of the bowl? Also, with a staight edge across the two headlamp bowls, should drivers side outer and inner edges of the bowls be in line with passenger side inner and outer bowl edges?
Ian
Ian
Hi Guest!
