zottlander
Member
ok so i have taken it all apart down to the head. i have tried the leave the plugs in and use compression to part the head from block. The head will not budge.I used a block of hardwood to try and tap it loose, no dice. Is there another method aside from incantations, incense burning, or animal sacrifice to remove the spitfire head? The previous owner had ground down the faces of the rockers, i think this was to avoid buying shorter pushrods.
