Hello guys,
I have a 75 TR6 with a master light switch on the dash and a dimmer switch on the column. The parking lights work fine when I turn them on using the master light switch. If I try to turn on the headlights I only have the tail lights on - no head lights. In addition, if I use the dimmer switch to flash the headlights, the headlights will flash so I know the headlights have power. I have tried cleaning the dimmer switch contacts but it has not helped. Do you think the problem is the dimmer switch or am I missing something? Any suggestions would be appreciated.
Bill L
Bill L
