You can get it done in a day. There will be a lot of argument on this second part, but I use copper spray on my head gaskets. I never had one leak that way. I had a high compression head on the car at first. It had compression numbers of 245lbs per cylinder and no leaks! Lots of power too but very expensive due to the high octane needed for the engine. When you get everything diconected, you might have to break the head free by turning the engine over a few times or hook a chain to the valve covers and put a piece of wood that will extend to both sides of the car. With a friend, you can lift it off without hurting your back.
