tahoe healey
HELP!
So now that I've pulled the head form the engine, I see swirl ridges on the under side of the head. I've done an MGB and Jag XK180 but have never seen these ridges form machining. I'm assuming the oil seepage is oil running along these ridges and out the side of the block (on the spark plug side and rear at the trans).
Can I use some form of sealent on the head gasket on that side or do I need to find a shop that can smooth this flat?
Or, is it suppose to be this way?????
I hate supprises!!!!!
By the way, I've always had good compression and oil pressure of 60 to 40 when hot.
Hi Guest!
