Are in final phases of restoration of a 64 bj8 with HD8 carbs. New electronic SU pump with a Faucet type backup pump in line with the SU. Have glass fuel filter between tank and SU pump. Original fuel tank was cleaned and sealed. Gas cap is vented.
During first few miles of test driving with approx 1/4 tank of ethanol free gas (glad we can get that in FLA) car was running fine as we were getting carbs into adjustment. Then put more gas to about 1/2 tank. Did about a 1/2 hour test drive and at the end the car slowly ran out of fuel, yet I could hear the SU still pumping. Switched to the backup pump and same thing, car would not run. After letting it sit for a about 5 minutes, car started and got it home (3 miles away) and pulling into driveway, died again. We confirm that there was no fuel as we pulled of the tops of the float bowls which were empty. Reinstalled and stated back up, but again after a few miles of driving out of fuel once again.
So we measured the amount of fuel the SU was delivering by disconnecting the braided line to the carbs and running the pump for 30 seconds and measured the fuel in a container. I have read that the SU pump should put out about 15-18 gal/hour, or just over a quart/minute. So in 30 seconds we should see about 16 or so ounces of fuel. We are getting just 5oz/30 sec with either pump running.
We have read all the past posts and did all the usual checks. The fuel filter was clean, no debris in the bottom of the float bowls. Then we disconnected the line just before the filter (which is before the SU) and blew compressed air back into the tank. Checked the fuel rate once again, the SU is now at 10 oz/30 seconds and the Faucet type pump is still only getting 5 oz/30 sec. To achieve the 15-18 gal/hour spec, once should get about a pint (16oz) in 30 seconds, or a quart/min.
So what is the minimum fuel rate needed to keep the bowls full running at normal highway speeds? Is 10oz/30 sec enough as we will soon find out with another road test. Apparently the Faucet type backup pump can only deliver the 5oz/30 sec, which seems like it is not enough to let the car run at normal speeds.
Also apparently we do (did) have some debris between the tank and the pump. The line is new so it must be in the tank. We will try to blow air again to see if can improve the rate. Past posts say original tanks did have a screen inside the pickup and they can become clogged when the tank is cleaned and coated.
Any thoughts on what is going on here, how to clean the tank filler tube?
Thanks
jjs64bj8
Thanks
jjs64bj8
Hi Guest!
