T-Series Hazard Switch
kyreb1862
Ok, exactly how do I get the hazard switch out of the dash? I've got a bad connection on the hot wire to my turn signals.
Its just real tight - but, you push it out from the back on a '77.
I'm sure someone else has an easier way, but i am messing with my hazard switch as well.
You have to remove the center console (which means you have to remove the tunnel console as well)
There should be a clamp behind the switch. (the clamp contains the light)
once you pry the clip away from both sides of the swich it should push trough the center console.
Rob
