Do you mean the switch or the indicator light or the flasher unit itself? The switch is directly in front of the driver on the dash. Should be mounted in between the speedo and the tach. A red knob with a triangle on it. The indicator light is below it (rectangular). The flasher unit itself is the same unit as used for turn signals. Follow the green/light-green stripe wire from the turn signal indicator light - it will lead directly to the flasher unit.
