Hawk Coil Over
Gary
I see you are doing a disc brake conversion on the rear of your B. What Wilwood parts did you buy to do this? I'd like to do the same to my B project. Thanks.
This is where the conversion came from:
https://www.fast-mg.com/
"off road only" which means don't call them if you have an accident but it is very simple. I am not sure what the disk come from but mus be available. I'll try to get a # off the calipars. They are quite a bit smaller then the fronts which is good. The brackets are quite simple.
Gary
Mine is complete...I also used Rover SD-1 4-pot brakes on mine!
