I'm experimenting with putting some late TR4/4A upper A-arms and ball joints on the front suspension of my TR3A. Has anyone done that, and how did it work out? Are there any problems with doing this?
I put them on one side of the car today. I have taken the jack out from under the bottom pan and let the suspension go down against the new rubber stops. It appears that the center of the TR4 ball joint (using the grease fitting hole as reference) is about 1/2 (plus) inch in front of the center point of the spring housing. The TR3 ball joint sets right in the middle of the spring housing where there is a V-shaped cut out in the center of the spring housing. Will this 1/2 inch forward position of the late TR4 ball joint cause any problems?
When I measured the distance from the shock absorber top bolt to the center of the ball joint grease fitting hole, both TR3 and the TR4 ball joints were right at 6-1/8 inch, so it does not seem to affect the camber. However, I have not put the car down on the wheels yet so I may be premature in saying camber is the same for both TR3 and TR4 A-arms. Does anyone have experience with this?
Thanks and Regards,
Bob
Thanks and Regards,
Bob
Hi Guest!
