Rob Glasgow
I want to replace the headliner in a factory hardtop on my BT7. Have removed the front pad and small side panels, but can't figure out how to remove the headliner and frame. I've been told I can pry the frame up/over the aluminum door frames, but there doesn't seem to be enough give. Do I need to remove one or both of the aluminum frames arround the door openings? If so, are they glued to the fiberglass and difficult to remove without bending? Any advice would be appreciated.
Rob
Rob
