Would anyone have an answer concerning hard shifting on my '73 TR6. 1st and 2nd gear seems to give in only after throwing the shifter back and forth between 4th and 3rd. The shifting problem is fine when your on the move. Once you stop, you have to struggle again to catch 1st. The clutch seems to be engaging and disengaging o.k. The throw out bearing is a bit noisy at times. Do you think that the gear box might be the problem.
To all my friends out there, thanks for your help.
Frank
Frank
