Happy Fourth to all of you .
Have a question with reagards to handling, There is a road I travel that has two raised expansion joints about two feet from each other. If I go over these joints while accelerating through the gears there seems to be a noticable sway fronm the rear twoards the drivers side(as if you were turning on real low air pressure in your tires. let of the gas it goes away. Normal bumps and raised expansion joints have no effect other than going over a bump.Is this the beginning of a problem or just a coinsidence on this part of the road?? Could travel a different road (lol). thanks for any help. p.s the car is 70 roadster no od.
Bob J
Bob J
