Ok, so I started to install new U-joints in my half axel shafts on my Jag's IRS. I had the axle shafts and yokes out on the bench and figuered, how hard can this be? I've installed U-joints before. No big deal, right? Wrong! I managed to get one side installed, except that once I got the bearing caps far enough in to allow the C-clips to install, now the U-Joint yoke will not rotate - it is frozen solid! Any ideas? I may have to send these out to be done and I'm pretty sure this one new U-joint is probably wasted. Very depressing!
[ 07-22-2002: Message edited by: Basil ]</p>
