Which links did the Elan use? There are two distinct styles: one is what you have -- with the hole through which the tie rod link passes -- used on GT6 (and at least similar to, if not interchangeable with, that on many Heralds, although stub axles differ between the two regardless) -- and the other, as found on all but the earliest Spitfires, does NOT have that hole. I'm thinking it's gonna be easier and cheaper regardless to seek out a "Triumph" part than a "Lotus" part.
For reference only (NFI):
GT6
Spitfire, FC15576 and later
The other obvious difference between the two is that the Spitfire link has "ears" for mounting the caliper, while the GT6 caliper mounts to a plate that bolts onto the vertical link.
GT6
