GT6 GT6 Parts wanted...
Flinkly
hey,
so my gt6 frame is pretty trashed and that is the part i want the most. i'm willing to take any gt6 frame and convert it to a rotoflex frame myself. i'm also looking for just about anything else, so if you have a parts gt6, i'd be interested in taking some parts off your hands. I have tried to get the last two gt6's off of craigslist but they are always gone before i can get a hold of the seller. keep a look out too, thanks everyone.
Hi,
It's a bit of a ways from you, here in N. Calif., but I assume you saw https://sfbay.craigslist.org/eby/car/190201638.html that I posted about earlier. Sounds like the seller will let everything go pretty cheap. It's hard to tell from the pics if the frame is okay or not. At least it's in a relatively dry part of the country and isn't sitting directly on the ground.
Hope this helps!
You might try these boards to obtain GT6 parts. Both are friendly and manned by very knowledgeable GT6 enthusiasts:
https://members.boardhost.com/GT6-Spitfire/
Also, try the Yahoo Groups "GT6 enthusiast" board, it's small in numbers but very helpful.
Cheers, good luck with your six!
Too bad you're on the Left Coast. I've got a usable GT6+ frame that you could have cheap. It would need some straightening of the very front crossmember (where your bonnet pivots would have to be transplanted on, anyway) and possible replacement of a front side outrigger or two (readily available). But I'm in NY, near Albany, so that doesn't help much.
