dklawson
I tried "search" on the assumption I'd find old threads on 6-cylinder oil pressure but I didn't locate any. Forgive me if this has been beaten to death and I simply missed an old thread.
On the way home from a show last month our GT6 started running hot to the point that it thinned the oil down enough to trip the pressure switch at idle.
I tested the switch and found it changed state at 22-25 PSI. Further checking showed that the factory switch was supposed to change state at about 5 PSI.
I have since installed a new/correct pressure switch, flushed the radiator, fitted an oil pressure gauge, and done a bit of additional work to improve the cooling situation.
On other cars/engines I've worked with I've been told that a good rule of thumb is for the engine to have 10 PSI of oil pressure for every 1000 RPM. Does that hold true for the 6-cylinder TR engines? My hot idle oil pressure at 1000 RPM is right at 25 PSI which would be acceptable on other cars I've had. Is it OK with the GT6? (Cold oil pressure is very good... near 75 PSI with a fast idle near 2000 RPM).
