The ground path on the early TR's leaves something to be desired. As originally configured, the battery grounds to the body and the engine grounds to the frame. Bonding of the body to the frame is incidental. That is, there is no discrete conductor (wire). Rather the ground path is through all of the bolts and components that attach to the frame and body like rear fender stays, radiator, speedometer/tachometer cables, etc. I ran into a conductivity issue during reassembly recently. Seems my efforts to ensure the chassis and body were well painted, mounted with new rubber packings and such pretty well insulated the body from the frame. I added an additional ground strap between a bellhousing bolt and the firewall, and all was well. Triumph apparently figured this out over time, look at a TR6 ground cable.
