This tr3 is kicking my butt. In an effort to make it run well,I decided to replace the Gross jets with the new standard type. I now have fuel pumping out of the over flow on the front carb. My first thought is the 7/16 setting is off, but that’s ok. It seems like too much fuel pressure. It has a very strong pump out. Anyone heard of a stock fuel pump failing by giving too much fuel? Tomorrow I will probably put a pressure reducer on and see what happens or maybe swap out a pump. I wonder if that gas tank slag has plugged up something and causing too much pressure.
