You mean this one ?KVH said:I don't know about this. I just tried one and I can't see how it could be drawing all the air out of the lines.
Does anyone have experience with this product?
PeterK said:I have a Motive https://www.motiveproducts.com/ pressure bleeder. Instead of vacuum, it uses low pressure to push fluid from the M/C reservoir (vs pumping the pedal) and then bleed as normal. You can use Speed bleeders too if you want. My wife loves it cuz' she no longer has to sit and pump the pedals.
You can buy their adapters or DIY with old M/C caps.
DrEntropy said:Eezi-Bleed here, used it for years in a 'production environment'. Low pressure 'pusher' from the M/C.
