lclark0624
Hey, after all this time we are running, with power. Although I had checked the diaphram at least 6 times, I didn't see a pin hole leak until I held the thing to the light. I also got the water choke spring adjusted by putting it into boiling water and then remarking it.
HOWEVER, The only problem is that it's running away. It'll go into the red if I don't shut it off first.
I adjusted the needle at the end of the piston all the way down, but that had no effect.
Any bright ideas how to stop this runaway? /ubbthreads/images/graemlins/frown.gif
Hi Guest!
