Greasing the distributor of BN6
BN6_2197
Another rookie question on greasing: I want to grease the drive shaft of the distributor. Is it just by removing the screw including the spring and putting some grease into the "hole"?
Volker
Volker
I think that your distributer should have a lubricator on the side ( not sure if that is what you are describing), remove the top of it, pack it with grease and put it back on. Then from time to time give it a turn or so to drive the grease onto the spindle.
:cheers:
Bob
